It is currently Sun Sep 14, 2025 10:48 am
 Post subject: Moxon Vise Finished
PostPosted: Wed Jan 10, 2024 11:58 am
First name: Karl
Last Name: Borum
Zip/Postal Code: 63303
Finished the Moxon vise. Thanks for all the suggestions. I chose the Moxon style because its portable and can be moved from bench to bench, can hold long stock for sawing, and conserves valuable space in my small cramped shop. Vise has provision for clamping to bench edge.
For the body clamping jaw inserts, I used .090 thk mahogany practice-sides, covered with thick leather, using one thickness of mahogany spacer and one thickness of leather to create the needed top and back radius. The body clamping jaws slip on and off, over the threaded press screw. I will add a wide, adjustable belt webbing “sling” to catch a body that inadvertently slips through the jaws.
Hard Maple jaws, shellac finish
12” Jorgensen Pony Press Clamps w/ Acme Thread
Slotted movable jaw to eliminate racking (can easily clamp tapered pieces)
Measure Twice,
Karl Borum
These users thanked the author Kbore for the post (total 5): Robbie_McD (Thu Jan 11, 2024 10:04 am) • Doc (Thu Jan 11, 2024 8:06 am) • kyle.medeiros (Wed Jan 10, 2024 8:05 pm) • Bryan Bear (Wed Jan 10, 2024 12:34 pm) • bcombs510 (Wed Jan 10, 2024 12:02 pm)
 Post subject: Re: Moxon Vise Finished
PostPosted: Wed Jan 10, 2024 12:06 pm
That's pretty nice great job Karl!!
These users thanked the author Hesh for the post: Kbore (Thu Jan 11, 2024 1:24 pm)
PostPosted: Wed Jan 10, 2024 12:09 pm
Very handy!
These users thanked the author meddlingfool for the post: Kbore (Thu Jan 11, 2024 1:24 pm)
PostPosted: Wed Jan 10, 2024 5:10 pm
Last Name: Ball
Sweet!
These users thanked the author ballbanjos for the post: Kbore (Thu Jan 11, 2024 1:24 pm)
PostPosted: Wed Jan 10, 2024 7:07 pm
First name: Brad
Last Name: Combs
Nice!
These users thanked the author bcombs510 for the post: Kbore (Thu Jan 11, 2024 1:24 pm)
PostPosted: Thu Jan 11, 2024 10:48 am
The press screws look handier than the pipe clamps many designs use. Nice!
How wide can the vise go?
These users thanked the author Clay S. for the post: Kbore (Thu Jan 11, 2024 1:47 pm)
PostPosted: Thu Jan 11, 2024 12:15 pm
First name: Bryan
Last Name: Bear
City: St. Louis
State: Mo
I mentioned this to Karl off line but I'll add it here incase anyone is interested.
I made a two screw moxon style vise built into my bench (probably similar to Clay's pipe clamp version). I made padded jaws just like a troji has out of plywood. They bolt into the chops of my vice and basically turn my two screw vice into a mounted troji for holding bodies. Just putting the two padded jaws away when not in use takes up much less space than an actual troji for those with limited shop space.
Bryan Bear PMoMC
These users thanked the author Bryan Bear for the post: Kbore (Thu Jan 11, 2024 1:25 pm)
PostPosted: Thu Jan 11, 2024 1:46 pm
First name: Karl
Last Name: Borum
Thanks @Clay S.
7 7/16" wide between hardwood jaws (inserts removed)
6 3/16 wide between edge of jaw inserts (inserts installed)
7 1/8 wide between center of jaw inserts (accommodates 15/16" of center-to-edge dome)
I could increase all above widths by 1/2"- 5/8" in a pinch (no pun) :roll:
Opening width:
Hardwood jaw thickness: 1 1/4" thick
Double washer thickness on back of moveable jaw: 1/4" thick (easily removable)
Measure Twice,
Karl Borum
PostPosted: Mon Aug 05, 2024 7:02 pm
First name: Karl
Last Name: Borum
Eight months later, I finally cut a mortise with the box in the vise.
I added a simple hammock / cradle under the body for insurance. It added stability as well, a very easy, inexpensive and worthwhile upgrade- just a 1” strap (I used 2 because I didn’t have one long enough.
I’ve had to tool up, significantly, to make my own necks….
Pics in reverse order [headinwall]
Measure Twice,
Karl Borum
These users thanked the author Kbore for the post (total 2): bcombs510 (Mon Aug 05, 2024 7:13 pm) • SteveSmith (Mon Aug 05, 2024 7:04 pm)
PostPosted: Mon Aug 05, 2024 7:14 pm
First name: Brad
Last Name: Combs
Nice! The strap is a great idea!
These users thanked the author bcombs510 for the post: Kbore (Mon Aug 05, 2024 9:35 pm)
PostPosted: Tue Aug 06, 2024 9:56 am
First name: Bryan
Last Name: Bear
City: St. Louis
State: Mo
I like the strap underneath. That is a great idea!
Bryan Bear PMoMC
These users thanked the author Bryan Bear for the post: Kbore (Tue Aug 06, 2024 6:34 pm)
PostPosted: Tue Aug 06, 2024 12:26 pm
First name: Carl
Last Name: Dickinson
City: Forest Ranch
Zip/Postal Code: 95942
I use a couple of bands cut from a tire inner tube for that. Works for me.
These users thanked the author CarlD for the post: Kbore (Tue Aug 06, 2024 6:34 pm)
PostPosted: Tue Aug 06, 2024 4:24 pm
Looks good! I have a Veritas twin screw vise that I use with some 1 1/2 ethafoam padding but I like the flexible plywood idea and the strap is also a good idea. I have pieces of pool noodle for covering the screws in case I get klutzy. :)
These users thanked the author Darrel Friesen for the post: Kbore (Tue Aug 06, 2024 6:34 pm)
PostPosted: Tue Aug 06, 2024 6:35 pm
First name: Karl
Last Name: Borum
I need pool noodle!
I also need to cap the back side of the screws, they are extra long and an accident waiting to happen.
Measure Twice,
Karl Borum
Users browsing this forum: Gary Davis, Geocoucou79 and 38 guests
